RIDGID R84015 X2 Wiring Repair
  1. RIDGID R84015 X2 Wiring Repair, RIDGID R84015 X2 Case Removal: step 1, image 1 of 2 RIDGID R84015 X2 Wiring Repair, RIDGID R84015 X2 Case Removal: step 1, image 2 of 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Wiring Repair: step 2, image 1 of 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Wiring Repair: step 3, image 1 of 2 RIDGID R84015 X2 Wiring Repair: step 3, image 2 of 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Wiring Repair, RIDGID R84015 X2 Wiring Repair: step 4, image 1 of 1
    • Use a multimeter set above 18V DC to check electrical connections where wires meet drill, switch, or battery terminal.
  5. RIDGID R84015 X2 Wiring Repair: step 5, image 1 of 1
    • Look for corrosion or burnt wires.
    • If there are any bad connections or if there is visible damage, replace damaged wire and solder.
    • After soldering sand off jaged solder then wrap with electrical tape
Evan Long
262 Reputation
4 Guides authored
Cal Poly, Team 15-48, Garner Spring 2010 Member of Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 18
All Time: 5,192
