Resetting PlayStation 3 Drive Mechanism
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Resetting PlayStation 3 Drive Mechanism, Resetting PlayStation 3 Drive Mechanism: step 1, image 1 of 1
    • Remove Rubber Foot
  2. Resetting PlayStation 3 Drive Mechanism: step 2, image 1 of 1
    • Remove Screw with a TORX Security T10 Bit (or you can use a small flat head screwdriver)
  3. Resetting PlayStation 3 Drive Mechanism: step 3, image 1 of 1
    • Carefully slide the top plate and lift to remove
  4. Resetting PlayStation 3 Drive Mechanism: step 4, image 1 of 1
    • Remove the main screws (philips head)
  5. Resetting PlayStation 3 Drive Mechanism: step 5, image 1 of 1
    • Lift The Top Casing Towards the front of the PS3 carefully
  6. Resetting PlayStation 3 Drive Mechanism: step 6, image 1 of 1
    • Carefully Remove Power cable from the motherboard
  7. Resetting PlayStation 3 Drive Mechanism: step 7, image 1 of 1
    • Lift the Disk drive to the right and remove the largest ribbon cable by lifting the black catch and remove the drive from the PS3
  8. Resetting PlayStation 3 Drive Mechanism: step 8, image 1 of 1
    • Remove Screws 11, 12 and 13 only
  9. Resetting PlayStation 3 Drive Mechanism: step 9, image 1 of 1
    • Remove screws 14 and 15 and the silver springboard, slightly bend top metal away from disk entry area,and pull back to remove the metal jacket.
  10. Resetting PlayStation 3 Drive Mechanism: step 10, image 1 of 1
    • Remove white center hub piece (D) and screws 16 - 20 then fold the top section to the left being careful not to damage the cable to the bottom left. The cable is very delicate and easily damaged.
  11. Resetting PlayStation 3 Drive Mechanism: step 11, image 1 of 1
    • Remove the screw circled in red and lift up the black assembly to reveal the mechanism beneath. Set it aside right-side up and be careful not to shake any parts loose.
  12. Resetting PlayStation 3 Drive Mechanism: step 12, image 1 of 1
    • Remove two screws in blue and lift the motor up and to right to disengage the cogs but be careful not to stress the attached wires.
    • Move the disc handling element on the left side up so that its teeth are clear of the black cog.
    • Reset insertion trap lock mechanism and make sure the white tab on right is lowered (nudge it left to make it drop).
    • Replace the motor and reverse this guide to reassemble.
15 other people completed this guide.
David Harris
816 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 15,929
