PSP 1000 Button Board Replacement
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. PSP 1000 Button Board Replacement, Button Board: step 1, image 1 of 3 PSP 1000 Button Board Replacement, Button Board: step 1, image 2 of 3 PSP 1000 Button Board Replacement, Button Board: step 1, image 3 of 3
    • That's my PSP. As you can see, the UMD door it's broken. It fell down when I was playing.
    • That's the part where the screws are located. You must move away the battery before doing nothing.
    • We must unscrew the screws marked with colour blue.
    • Remind to keep safe the screws, because you can loose them!
  2. PSP 1000 Button Board Replacement: step 2, image 1 of 1
    • After unscrew the screws we can move away the front case.
    • This is the button board. In my case it's damaged.
  3. PSP 1000 Button Board Replacement: step 3, image 1 of 3 PSP 1000 Button Board Replacement: step 3, image 2 of 3 PSP 1000 Button Board Replacement: step 3, image 3 of 3
    • This is one of the two clips which the button board has. With an oppener tool you should release it.
    • Be careful with this ribbon cabble!
  4. PSP 1000 Button Board Replacement: step 4, image 1 of 2 PSP 1000 Button Board Replacement: step 4, image 2 of 2
    • Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch, and we are done! Be careful with the latch because it brakes easily!
Javi
227 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 7
All Time: 1,231
