Nokia 6102i motherboard replacement
  1. Nokia 6102i motherboard replacement, Battery: step 1, image 1 of 3 Nokia 6102i motherboard replacement, Battery: step 1, image 2 of 3 Nokia 6102i motherboard replacement, Battery: step 1, image 3 of 3
    • Press and hold the button at the bottom of the back side of the phone while sliding the back plate down to remove the back cover.
    • Note: Images on the right side may be hovered over to reveal larger versions.
  2. Nokia 6102i motherboard replacement: step 2, image 1 of 1
    • Lift up the battery from the inside of the phone.
    • Make sure to lift up from the bottom of the battery as shown.
  3. Nokia 6102i motherboard replacement, Logic Board: step 3, image 1 of 2 Nokia 6102i motherboard replacement, Logic Board: step 3, image 2 of 2
    Tool used on this step:
    T6 Torx Screwdriver
    $9.99
    Buy
    • Using a .208 head T-6 Screwdriver remove the two screws at the bottom of the battery cavity.
  4. Nokia 6102i motherboard replacement: step 4, image 1 of 2 Nokia 6102i motherboard replacement: step 4, image 2 of 2
    • Use a plastic opening tool to remove the silver cover over the antenna.
    • The covering may not pop right off. It may require some prying in different locations around the top covering.
  5. Nokia 6102i motherboard replacement: step 5, image 1 of 2 Nokia 6102i motherboard replacement: step 5, image 2 of 2
    • Remove the two newly revealed .208 inch screws at the top using a T-6 screwdriver.
  6. Nokia 6102i motherboard replacement: step 6, image 1 of 2 Nokia 6102i motherboard replacement: step 6, image 2 of 2
    • WARNING: Use extreme caution when removing and handling the logic board as it is very fragile.
    • With caution, use a plastic prier to separate the back silver casing from the front of the phone. This may require force.
    • Disconnect the logic board from the small orange chip.
2 other people completed this guide.
Alex Graebe
1 Reputation
2 Guides authored
Cal Poly, Team 23-78, Johann Spring 2010 Member of Cal Poly, Team 23-78, Johann Spring 2010
CPSU-JOHANN-S10S23G78
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 2,645
