Repairing Nintendo Wii Drive Board Fuses
User-Contributed Guide
Solve problems with eject and spindle motor action by replacing SMT fuses.
  • Author: bushing
  • Time required: 45 minutes
  • Difficulty: Very difficult
  • Add Note x
  • x 5
If you have a drive which fails to spin the disc up or properly eject or "eat" discs, you may have one or two blown fuses on the drive PCB. This guide will show you how to test and replace those fuses!
Tools (continued)
Relevant Parts
Image #1 Image #2
Add Note Edit Step 1 — Faceplate  ¶
  • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Image #1
Add Note Edit Step 2  ¶
  • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
Image #1
Add Note Edit Step 3  ¶
  • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
Image #1
Add Note Edit Step 4  ¶
  • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
Image #1
Add Note Edit Step 5  ¶
  • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Carefully pull the faceplate away from the front of the Wii.
  • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
  • Remove the faceplate.
Image #1 Image #2 Image #3
Add Note Edit Step 7 — Outer Case  ¶
  • Open the controller port cover until it is perpendicular to the black controller port bezel.
  • Pull the controller port cover straight up to release it from the outer case.
  • Repeat this procedure for the memory card port cover.
Image #1 Image #2
Add Note Edit Step 8  ¶
  • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
  • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
Next » « Previous
Required Tools
Soldering Station
$24.95 · 14 In stock
Desoldering Braid
$4.95 · 50+ In stock
Popular Device Products
Nintendo Wii DVD Drive
$79.95 · 4 In stock
