Nintendo 64 Bottom Cover Disassembly
  1. Nintendo 64 Bottom Cover Disassembly, Top Cover: step 1, image 1 of 1
    • Remove the expansion pack cover by pushing in the tab and pulling out.
  2. Nintendo 64 Bottom Cover Disassembly: step 2, image 1 of 1
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
  3. Nintendo 64 Bottom Cover Disassembly: step 3, image 1 of 1
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
  4. Nintendo 64 Bottom Cover Disassembly: step 4, image 1 of 1
    • Remove the two front feet of the N64.
  5. Nintendo 64 Bottom Cover Disassembly: step 5, image 1 of 1
    • Rotate to top side up and lift off top cover.
  6. Nintendo 64 Bottom Cover Disassembly, Metal Plate: step 6, image 1 of 2 Nintendo 64 Bottom Cover Disassembly, Metal Plate: step 6, image 2 of 2
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
  7. Nintendo 64 Bottom Cover Disassembly: step 7, image 1 of 2 Nintendo 64 Bottom Cover Disassembly: step 7, image 2 of 2
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
  8. Nintendo 64 Bottom Cover Disassembly: step 8, image 1 of 1
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
  9. Nintendo 64 Bottom Cover Disassembly: step 9, image 1 of 1
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
  10. Nintendo 64 Bottom Cover Disassembly: step 10, image 1 of 1
    • Remove the small metal bracket from the back of the expansion pack slot.
  11. Nintendo 64 Bottom Cover Disassembly: step 11, image 1 of 2 Nintendo 64 Bottom Cover Disassembly: step 11, image 2 of 2
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
  12. Nintendo 64 Bottom Cover Disassembly: step 12, image 1 of 2 Nintendo 64 Bottom Cover Disassembly: step 12, image 2 of 2
    • Remove the small metal bracket behind the expansion slot using the spudger.
  13. Nintendo 64 Bottom Cover Disassembly: step 13, image 1 of 2 Nintendo 64 Bottom Cover Disassembly: step 13, image 2 of 2
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
  14. Nintendo 64 Bottom Cover Disassembly: step 14, image 1 of 1
    • Lift off and remove the metal plate as indicated in the example.
  15. Nintendo 64 Bottom Cover Disassembly, Motherboard: step 15, image 1 of 1
    • Remove the four screws indicated using the #1 Phillips screwdriver.
  16. Nintendo 64 Bottom Cover Disassembly, Motherboard removal: step 16, image 1 of 1
    • Lift up and remove the motherboard.
  17. Nintendo 64 Bottom Cover Disassembly, Nintendo 64 Bottom Cover Disassembly: step 17, image 1 of 1
    • Remove everything from the bottom cover.
23 other people completed this guide.
tonymag28
2,154 Reputation
3 Guides authored
Cal Poly, Team 5-4, Regan Fall 2009 Member of Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Members
15 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 183
All Time: 40,224
