Repairing Mac OS X Disk Permissions
This guide will help you to verify and repair disk permissions, keeping your Mac healthy.
  • Author: Mike
  • Time required: 5-10 minutes
  • Difficulty: Very easy
This guide is for those whose battery is not being recognized by their computer or that their computer is having issues with user permissions. It is a fairly simple repair, but can manage to solve some issues that arise from doing various repairs.
Image #1 Image #2
Add Note Edit Step 1 — Disk Permissions  ¶
  • You will want to first open Disk Utilities, which can be found in the Applications folder under Utilities
    • Or you can take the shortcut and use Spotlight!
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Once opened, you should be presented with a window that looks like this.
    • You will want to select the name of your Mac OS X Startup disk in the left column.
  • After clicking on the name of your Hard drive, you will be presented with a few different options at the top.
    • The First Aid heading is what you will want to be under.
  • Click on the Verify Disk Permissions, starting the process.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • This usually will take anywhere from 3 minutes to 15 minutes. The best thing to do is to wait.
  • As time progresses, you will see information pop up in the window highlighted.
    • This is good, it means that it is seeing the problems that may be keeping your computer from running well.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • After verifying the disk permissions, go ahead and select repair disk permissions to start that process.
  • During that time, which again should take anywhere from 3-10 minutes, feel free to get up, walk around for a few minutes, or go pet a cat.
Popular Products
Plastic Opening Tools
$2.95 · 50+ In stock
Magnetizer/Demagnetizer
$4.95 · 50+ In stock
T10 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Helping Hands
$8.95 · 50+ In stock
