Repairing IBM ThinkPad T41 Speakers
User-Contributed Guide
Step Trimmer
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
This is a step by step guide for replacing/repairing the speakers of an IBM ThinkPad T41 laptop. It will aid you in taking apart your laptop to reach the speakers.
This repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its speakers.
Sections
Image #1
Add Note Edit Step 1 — Keyboard  ¶
  • Close the screen and turn the closed laptop over.
  • Remove all 17 screws on the bottom of the computer.
  • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
  • Your computer may have more if it still has its optical device, HDD, or battery. The yellow markers are the location of at least two extra screws that we don't have.
Image #1
Add Note Edit Step 2  ¶
  • Remove the extra RAM cover, by lifting where the screw was and pulling out.
Image #1
Add Note Edit Step 3  ¶
  • Turn the laptop right side up and open the screen.
  • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
  • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
Image #1
Add Note Edit Step 4  ¶
  • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
Image #1
Add Note Edit Step 5 — Trackpad  ¶
  • Close the laptop and turn it over.
  • Remove the five plastic stickers covering the screws on the front edge of the case.
  • In order to reuse the stickers, remove them carefully.
Image #1
Add Note Edit Step 6  ¶
  • Unscrew the five screws that were hidden by the stickers.
Image #1
Add Note Edit Step 7  ¶
  • Turn the computer right side up and open the screen.
  • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
  • Careful of the ribbon cable underneath, which may tear if trackpad is pulled too vigorously.
Image #1
Add Note Edit Step 8  ¶
  • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
Image #1
Add Note Edit Step 9 — RAM  ¶
  • Push apart the retaining clips on the RAM.
  • Note: The RAM should pop up a little bit.
Image #1
Add Note Edit Step 10  ¶
  • Lift out the RAM chip.
Image #1
Add Note Edit Step 11 — Wireless Network Card  ¶
  • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
Image #1
Add Note Edit Step 12  ¶
  • Push apart the retain clips.
  • Note: The card should pop up a little bit.
Image #1
Add Note Edit Step 13  ¶
  • Pull the wireless network card out.
Image #1
Add Note Edit Step 14 — BIOS Battery  ¶
  • Lift the yellow plastic-covered battery up.
Image #1
Add Note Edit Step 15  ¶
  • Unplug the battery connector.
Image #1
Add Note Edit Step 16 — Speakers  ¶
  • Lift the speakers out by starting with the left end and then unsnake the wires.
Image #1
Add Note Edit Step 17  ¶
  • Unplug the wires from the motherboard.
Required Tools
Spudger
$2.95 · 50+ In stock
Popular Products
Universal Drive Adaptor
$29.95 · 50+ In stock
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
iPhone 3GS Replacement Battery
$19.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Anti-Static Wrist Strap
$7.95 · 50+ In stock
