This teardown is not a repair guide. To repair your Gateway 420GR, use our service manual.
  1. Repairing Gateway 420GR, Repairing Gateway 420GR: step 1, image 1 of 1
    • The left panel of the case has thumbscrews that release the left side from the case.
  2. Repairing Gateway 420GR: step 2, image 1 of 1
    • Loosen the first thumbscrew
  3. Repairing Gateway 420GR: step 3, image 1 of 1
    • Loosen the second thumbscrew.
  4. Repairing Gateway 420GR: step 4, image 1 of 1
    • The side panel will now slide toward the back of the case.
  5. Repairing Gateway 420GR: step 5, image 1 of 1
    • System RAM
    • USB headers for front panel USB ports.
    • CMOS battery
  6. Repairing Gateway 420GR: step 6, image 1 of 1
    • Pair one RAM retention clips. There are two (one on each end) for each of the available slots.
    • Pair two RAM retention clips. There are two (one on each end) for each of the available slots.
    • RAM should be paired (same size) and the machine support up to 4GB or RAM as 1GB modules in each of the 4 slots.
    • System supported RAM is 184-pin DIMM DDR PC3200
kyle23
182 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 3,486
