Repairing Game Boy Speaker
User-Contributed Guide
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
How to replace the speaker in a first-gen Game Boy system.
How to access and replace the speaker on the front panel of a Game Boy system.
Relevant Parts
  • 8-ohm mini speaker Be careful with the replacement part. I have not been able to verify the specific stats for the speaker, so I would recommend asking an electronics professional. If you find this info, please edit them into this guide!
Image #1
Add Note Edit Step 1 — Replacing Game Boy Batteries  ¶
  • The Gameboy system uses four (4) AA batteries.
  • Turn over the Game Boy system and note the closed battery compartment.
Image #1 Image #2 Image #3
Add Note Edit Step 2  ¶
  • Use your fingernail to get underneath the battery cover latch. Proceed to remove the battery cover.
    • Be careful as this type of spring-clip is part of the cover itself and can break easily.
    • The plastic tabs at the bottom of the cover and the corresponding slots on the GameBoy unit must line up during re-assembly.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Remove each battery. Prying outward from the positive (+) terminal is the easiest way.
    • Do not dispose of used batteries with standard waste. Please refer to your local recycling department for proper disposal instructions of used batteries.
Image #1
Add Note Edit Step 4  ¶
  • Pay close attention to the proper orientation of the batteries prior to insertion. This is clearly labeled inside the compartment.
  • After fresh AA alkaline batteries have been inserted correctly, replace the battery compartment cover with care.
Image #1
Add Note Edit Step 5 — Outer Case  ¶
  • Remove the 6 screws on the back of the Game Boy system with a #00 Phillips Screw Driver.
    • Some Game Boys may have tri-wing screws securing the back case, rather than Phillips.
  • Place these screws in a safe place.
  • Be careful with these screws as they are easy to strip, and if this happens, they are almost impossible to remove.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Gently separate the front and back of the system, taking special care not to damage the ribbon cable connecting them.
  • Once you can see the ribbon cable, move the screen side down a little bit to expose the ribbon cable connector.
Image #1
Add Note Edit Step 7  ¶
  • Grip the ribbon connector with your thumb and forefinger, pulling gently until the ribbon connector comes out of its socket.
Image #1
Add Note Edit Step 8  ¶
  • The pieces should be completely separated and appear as shown in the image.
  • Note the location of mounting screws for the circuit boards.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Soldering Station
$24.95 · 16 In stock
Lead-Free Solder
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 10 In stock
Popular Products
iPad 2 Front Panel Assembly
$119.95 · 21 In stock
iPhone 4S Earpiece Speaker
$14.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 13 In stock
Pro Tech Toolkit Expansion 1
$79.95 · 11 In stock
