Repairing GEN 2 Wheelchair Patching a Tire Tube
  1. Repairing GEN 2 Wheelchair Patching a Tire Tube, Repairing GEN 2 Wheelchair Patching a Tire Tube: step 1, image 1 of 3 Repairing GEN 2 Wheelchair Patching a Tire Tube, Repairing GEN 2 Wheelchair Patching a Tire Tube: step 1, image 2 of 3 Repairing GEN 2 Wheelchair Patching a Tire Tube, Repairing GEN 2 Wheelchair Patching a Tire Tube: step 1, image 3 of 3
    • Unscrew the axle nut with a 19 mm wrench.
    • Unscrew the the axle bolt with a 19 mm socket wrench.
    • Remove the wheel from the wheelchair.
  2. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 2, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 2, image 2 of 2
    • Insert the 19 mm socket wrench between the rubber tire and the metal frame.
    • Any rigid flat metal object can be used for this step.
    • Carefully slide the 19 mm socket wrench all the way around the tire. Bend the wrench down to pop the tire out of the bead of the rim.
    • When undoing the tire, be careful using the back of the wrench because the tool can damage the tire tube and or wheel frame.
    • Reach inside the tire and remove the tube from the metal frame.
  3. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 3, image 1 of 1
    • Take the inner tube from inside the tire and submerge the tube in water.
    • Squeeze the tube gently looking for bubbles from the tube in the water.
    • You can use where the bubbles are forming to locate the hole in the tube.
  4. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 4, image 1 of 1
    • Dry off the tube.
    • Pull the tube out of the water and mark the location of the hole on the tube so that it can be found again.
  5. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 5, image 1 of 1
    • Use sand paper to texturize the tire tube.
    • Wipe off any excess rubber that was sanded off the tube.
  6. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 6, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 6, image 2 of 2
    • Apply a thin layer of rubber cement over the area that was marked.
    • The layer should be slightly bigger than the size of the hole.
    • Let the rubber cement set for 5 minutes.
    • Peel the patch off of the plastic backing.
    • Place patch over the area with the rubber cement and firmly press down until the patch is securely attached.
  7. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 7, image 1 of 1
    • Feel along the tire to check for and remove any objects stuck in the tire before replacing the tube.
    • Line up the air valve on the newly patched (partially deflated) tube with the hole on the metal frame before trying to insert the tube.
    • Working all around the tire, carefully push the tube back into place inside the tire.
  8. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 8, image 1 of 1
    • Inflate the tire to 50 psi. If there is no gauge, inflate the tire until the tire is hard.
  9. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 9, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 9, image 2 of 2
    • Insert the axle bolt into the center of the rear wheel.
    • Insert the wheel with the axle bolt into the lower back of the frame by screwing in the bolt.
  10. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 10, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 10, image 2 of 2
    • Secure the nut on the opposite side of the axle bolt and wheel. Tighten with 1/2 in or 19 mm wrench.
Finish Line
Kali Slaughter
207 Reputation
5 Guides authored
Cal Poly, Team 14-8, Maness Spring 2013 Member of Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 708
