Introduction
Step by step Dell Streak 5 LCD Replacement
The disassembly was pretty straight forward but it did reveal a hidden surprise regarding the internal memory.................................. Around the edge seems to always be the weak part on these devices ,the Ebay seller had sold around 700 screens for this particular model. The LCD screen was only £25 which is a steal considering its suppose to be a genuine Corning "Gorilla glass", On further inspection of the original screen and the replacement it appears to be possibly a Dell OEM replacement the serial numbers are not that far apart.
You have to pry the LCD out of the frame of the Streak ,it is held in with a strip of gum on either side.A tip here is to start at the top of the phones LCD edge as the bottom of the LCD panel has a couple of lugs which slide into the bottom to lock it in place. More than likely the Gorilla glass will separate from the LCD taking the digitizer with it this is ok.
Reassembly it pretty straight forward and will take a fraction of the time it did to tear it down.The only snagging point will be if the gum side strips came away with the Gorilla glass .I had to use some double sided tape layered on top of itself twice on one side. The finished article
Heres the time laps x5 reassembly video.............http://www.youtube.com/watch?feature=pla...
3 other people completed this guide.
