Repairing Clothes Dryer Drive Belt
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
In Progress
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Needs More Images
Needs More Images
A few more images would make this guide's procedures crystal clear.
Member-Contributed Guide
The Tumbler is driven by a drive belt. Due to use, at some time it is highly likely this will break. Therefor the tumbler will not turn around.
  • Author: Allardvdt
  • Time required: 30 - 60 minutes
  • Difficulty: Easy
How to replace a broken / worn-out drive belt.
Fairly easy repair. Most challenging is to locate the screws
Image #1
Edit Step 1 Drive Belt  ¶
  • * First take power cable from socket
  • * Remove all screws (approx. 13 pcs) which hold the back plate
  • * Remove Backplate. This is done by pushing it upward for about 0,5 cm due to a lip on each side. Then pull backplate away
  • Remove the cable shoes from the two inner heater elements (approx. 5cm long, thin brownish rods).
  • Remove the metal bracket holding the 2 thermostats. WATCH OUT: Do not remove the cable shoes as these might break off. Just remove the whole metal bracket.
  • Remove the cable shoe from the ground wire (top left) (most probably green wire)
  • Remove 3 screws from black plastic cover from condensorfan (lower left)
  • Remove the metal clip on the centre rod of the condensorfan. This is done by using a screwdriver bending back the front part of the clip partially and then pulling it off with plyers.
No image
Edit Step 2  ¶
  • Find the three places where black condensor cover is being held to condensor. depress them and pull cover off. Now you can also pull off the fan.
  • Remove screws on middle right (3 if I remember) Most probably the tumbler will fall some cm's now (don't be alarmed)
  • Remove the 2 tubes from the condensor bucket (top right
  • Remove top cover of Dryer
  • Remove the whole aluminium back plate from tumble dryer. Now you will be looking at the inside of the tumble.
  • Oil the two wheels on the back plate. Clean away any kind of dust / fabrick
  • Oil the two wheels (bottom left in Dryer) which are attached to condensor fan.
  • Seperate manual the springloaded wheels and place the new drive belt BETWEEN the two wheels and around the central rod of the condensor fan. Ensure that the ribbled side of the belt is facing inwards.
No image
Edit Step 3  ¶
  • bring the drivebelt around the whole tumbler. Make sure that belt is running vertically from te two wheels. turn the tumbler manually a couple of times to ensure it is running in a straight line and that it is not twisted.
  • re-assemble the backplate of the tumbler. To do this properly, lift the tumbler up a little so it is flush with the centre piece of the backplate.
  • when having reassembled the wires and replaces the screws of the tumbler backplate and cover of condensor fan, you can choose to power up the tumble dryer and have it do some powered turns to ensure that the drive belt is running straight. BE CAREFUL NOT TO TOUCH LIVE WIRES OR GET CAUGHT IN TURNING PARTS
  • whan satisfied, reassemble the rest.
  • Good luck
For more information, check out the Dryer device page.
Required Tools
T6 Torx Screwdriver
$5.95 · 50+ In stock
T6 Torx Screwdriver
$9.95 · 30 In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Flathead 3/32" or 2.5 mm Screwdriver
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
iFixit Lock Pick Set
Inspection Scope
$39.95 · 50+ In stock
Frictionless Ratchet
$24.95 · 50+ In stock
Portable Anti-Static Mat
$34.95 · 42 In stock
Popular Products
1 TB SSD Hybrid 2.5" Hard Drive
$139.95 · 4 In stock
Metal Spudger Set
$7.95 · 50+ In stock
Magnetizer/Demagnetizer
Comments Comments are onturn off
No comments.
Today: 0
This Week: 0
This Month: 16
All Time: 148
