Repairing Canon PowerShot Lens Error E-18
  1. Repairing Canon PowerShot Lens Error E-18, Repairing Canon PowerShot Lens Error E-18: step 1, image 1 of 1
    • Place camera lens facing upwards on the table.
    • Press and hold down the power button.
    • Simultaneously press down the shutter button.
  2. Repairing Canon PowerShot Lens Error E-18: step 2, image 1 of 1
    • Replace the batteries in the camera.
    • To open the battery cover slide the black lever on the underside of the camera and pull the cover toward the front.
    • Remove the old batteries from the camera and wait a few moments.
    • Put in a fresh set of batteries.
    • Close battery slide and power camera back on.
  3. Repairing Canon PowerShot Lens Error E-18: step 3, image 1 of 1
    • Put blow dryer in the "no heat" setting prior to plugging it in.
    • Plug in and turn the blow dryer on.
    • Blow air in the gaps between the lens.
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
2 other people completed this guide.
Tim
172 Reputation
1 Guide authored
Cal Poly, Team 7-31, Regan Winter 2011 Member of Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Members
12 Guides authored
One Comment
merci! mon appareil fonctionne à nouveau
nadia.labadi - Reply
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 101
All Time: 5,997
