Repairing Apple TV 1st Generation Power Light
User-Contributed Guide
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Step Trimmer
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Many Apple TV forums report a weakening or dimming of the white power indicator. This is due to premature failure of a white LED. It is possible to replace the LED and restore the power light.
  • Author: John Matheson
  • Time required: 1 Hour
  • Difficulty: Very difficult
This repair requires either an extremely fine tipped soldering iron and extremely steady hands, or an SMD rework station.
Tools (continued)
Relevant Parts
Image #1
Add Note Edit Step 1 — Logic Board  ¶
  • Remove the T8 Torx screw securing the metal shield to the case.
  • In order to remove the T8 screw, you must insert the screwdriver through the access hole in the metal shield, located near the PRAM battery.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Remove the T20 screw securing the metal shield to the case, located near the digital audio port.
  • Lift and remove the metal shield away from the upper case of the Apple TV.
Image #1
Add Note Edit Step 3  ¶
  • Use a pair of tweezers to pull the IR cable straight away from its socket on the logic board.
  • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
Image #1
Add Note Edit Step 4  ¶
  • Lift the left edge of the logic board (nearest the PRAM battery) upwards and slide it out of the case, away from the ports.
  • Be careful to not damage the ports when sliding the logic board out of case.
  • Logic board remains.
No image
Add Note Edit Step 5 — Power Light  ¶
  • Carefully peel back the two copper sticky grounding strips near the LED module.
  • Swing the outer aluminium case up and carefully slide it towards the connector side of the logic board until it comes off. Remove the two Phillips #0 screws securing the LED module.
  • Carefully unplug the module from the logic board to make it easier to work on, and remove it from the case.
No image
Add Note Edit Step 6  ¶
  • There are two miniature SMD LEDs, one is clear and one is yellow. Unsolder the yellow coloured LED, which is actually the white one - the clear SMD LED is amber when on. Replace with another high intensity SMD LED. I used a blue one to match my other hi-fi components. The anode (+) is marked on the circuit board and is away from the infrared receiver side. Reassemble is a simple reversal being sure to remember to reverse every step.
No image
Add Note Edit Step 7  ¶
  • SMD LEDs are difficult to find as a spare part. I carefully ground down a normal sized LED with a Dremil until it would fit. The only source of SMD LEDs I could find was LED bar lights in various colours such as these: http://www.jaycar.com.au/productView.asp...
  • Enjoy!
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 38 In stock
Soldering Station
$24.95 · 16 In stock
Desoldering Braid
$4.95 · 50+ In stock
$6.95 · 47 In stock
Popular Products
PC3-8500 4 GB RAM Chip
$49.95 · 43 In stock
iPhone 3GS Replacement Battery
$19.95 · 50+ In stock
Phillips #00 Screwdriver
Metal Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 24 In stock
