Installing iPod Nano 2nd Generation Bottom Bezel Bracket
  • Author: iRobot
  • Difficulty: Difficult
  • Add Note x
  • x 4
The metal bracket within your iPod.
first image
Add Note Edit Step 1 — Bottom Bezel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • When removing the the bottom bezel, be sure not to bend the plastic surrounding the dock connector.
  • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic bezel
  • Lift the bottom bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
first image
Add Note Edit Step 3 — Bottom Bezel Bracket  ¶
  • Remove the following two screws:
    • One #00 Phillips screw with a large head near the headphone jack.
    • One #00 Phillips screw with a smaller head near the side of the iPod. This screw strips easily, so be sure to press down firmly on the screwdriver.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Metal Spudger
$2.95 · 50+ in stock
Plastic Opening Tools
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
