Installing iPod Nano 1st Generation Battery Replacement
- Author: Walter Galan
- Difficulty: Very difficult
Battery not lasting long? Swap it out (requires soldering).
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit Step 2 ¶
The rear panel is secured to the front case by eleven clips permanently attached to the rear panel. These clips lock onto small tabs machined into the front case.
To free the tabs, they must be pushed down and away from the iPod's case. Note the location of all tabs on the rear panel. When using an iPod opening tool to free the rear panel, be sure to work the tool at the location of these clips.
Edit Step 3 ¶
Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
Insert the large iPod opening tool into the seam between the front case and rear panel of the iPod, below the dock connector. Run the tool back and forth to create an opening. The tool's edge should point toward the rear panel to prevent any accidental scratching of the aluminum front case.
Page 1 of 9
