Step 10
Insert the flat end of a spudger between the battery and the headphone jack side of the front case to pry the battery up off the adhesive securing it to the front case.
Rotate the battery out of the iPod and lay it next to the iPod. The battery is still soldered to the logic board by three wires, so don't remove it entirely.
Step 12
Grasp the end of the logic board near the battery connector with one hand, and hold onto the rest of the iPod with your other hand.
Make sure the logic board is lifted slightly above the white plastic notch on the battery side of the board. This notch prevents the board from sliding out in the next step.
Slide the logic board out of its holding brackets on the rear of the display.
The logic board is still connected to the iPod by two ribbon cables.
Notes
There are no notes
