Installing iPod Mini Headphone Jack Board
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 8
No audio? Replace the headphone jack!
Sections
Tools
first image
Add Note Edit Step 1 — Top Bezel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position.
first image
Add Note Edit Step 2  ¶
  • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
  • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
  • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
first image
Add Note Edit Step 3  ¶
  • Lift the top bezel off of the iPod.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 17 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
