first image
Add Note Edit Step 4 — Bottom Bezel  ¶
  • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
first image
Add Note Edit Step 5  ¶
  • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
  • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
first image
Add Note Edit Step 6  ¶
  • Lift the metal retaining bracket out of the iPod.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
iPad USB 10W AC Charger
$19.95 · 5 in stock
iPod Mini Replacement Battery
$14.95 · 28 in stock
Notes Add Note Notes are offturn on
