Installing iPod Mini Bottom Bezel
Add Note Introduction
The plastic part on the bottom of the iPod.
Tools used in this guide
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Bottom Bezel
  • Carefully insert a small flathead screwdriver in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
first image
Add Note Step 2
  • Use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket
first image
Add Note Step 3
  • Lift the metal retaining bracket out of the iPod.
Congratulations!
Share your repair story!
To reassemble your device, follow these instructions in reverse order. For more information, check out the iPod Mini device page.
Did you successfully follow this guide?
Add NoteNotes: Step 2
Flag Reply by LambdaCalculus Aug 18 @ 4:29 AM
Be *very* careful on the left hand side. It's almost too easy to scrape the click wheel cable and cause damage to it!
