first image
Add Note Edit Step 10  ¶
  • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
first image
Add Note Edit Step 11  ¶
  • Lift the battery off of the logic board and lay it to the side of the iPod.
first image
Add Note Edit Step 12  ¶
  • Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
Next » « Previous
For more information, check out the iPod Mini device page.
Did you successfully follow this guide?
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Related Products
iPod Mini Replacement Battery
$14.95 · 28 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
