Installing iPod 4th Generation or Photo Headphone Jack
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 9
No audio? Replace the headphone jack!
first image
Add Note Edit Step 1 — Rear Panel  ¶
  • Before opening your iPod, ensure that the hold switch is in the locked position. The orange bar should be visible, indicating hold is active.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Opening the iPod can be challenging. Don't get discouraged if it takes you a few tries before the iPod is opened.
  • Insert a large iPod opening tool into the seam between the plastic front and metal rear panel of the iPod, near the headphone jack. The tool's edge should point towards the metal rear panel to prevent any accidental scratching of the plastic front.
  • Run the tool along the top seam toward the upper left corner of the iPod. Press the tool into the corner, creating a small gap on the side of the case.
first image
Add Note Edit Step 3  ¶
  • Push the large iPod opening tool into the upper left corner of the iPod, creating a small gap along the side seam.
Next » « Previous
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ in stock
Plastic Opening Tools
$2.95 · 50+ in stock
Related Products
iPod 4G 20 GB Headphone Jack
$29.95 · 8 in stock
iPod 4G 40 GB Headphone Jack
$29.95 · 15 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 17 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
