Installing iPhone 3G Vibrator
Add Note Introduction
The vibrating part of the iPhone.
Paginated Single Page Steps
first image
Add Note Step 1 — Vibrator
  • Remove the two Phillips #00 screws from the dock-connector end of the iPhone.
first image
Add Note Step 2
  • There is a rubber gasket between the silver front bezel and black display assembly. A bit of force is required in this step to separate the iPhone's display assembly.
  • Use a small suction cup near the Home button to gently pull up the bottom portion of the iPhone's display assembly.
first image
Add Note Step 3
  • The display assembly is still connected to the iPhone by several cables, so don't try to remove it entirely just yet.
  • Rotate the display assembly up until it is at an angle of approximately 45 degrees.
Notes
There are no notes
