first image
Add Note Edit Step 4  ¶
  • Be sure to slide the metal spudger between the dock connector and the antenna cover, and not into the dock connector itself.
  • Insert a metal spudger into the slot between the dock connector and the antenna cover. Gently pry up near the two tabs to create a small gap between the antenna cover and the silver front bezel.
first image
Add Note Edit Step 5  ¶
  • Insert an iPod opening tool in the gap between the antenna cover and the front bezel. The wedge of the tool should be pointing towards the antenna cover. Slide the tool around the corner and up until you reach the metal backing.
  • Repeat the same procedure on the other side of the dock connector.
first image
Add Note Edit Step 6  ¶
  • Grasp the antenna cover on either side and slide it up and away from the iPhone. This requires some force. If it does not come free, ensure that the antenna cover is lifted up enough to free the catches.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Metal Spudger
$2.95 · 50+ in stock
Plastic Opening Tools
SIM Card Eject Tool
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
iPhone Gen 1 Replacement Battery
$14.95 · 18 in stock
SIM Card Eject Tool
iPad USB 10W AC Charger
$19.95 · 5 in stock
Notes Add Note Notes are offturn on
