iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
iMac Intel 27" EMC 2309 and 2374 Hard Drive replacement.
  • Add Note x
  • x 120
Upgrade your hard drive for more storage space!
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Glass Panel  ¶
  • Stick a suction cup near each of the two top corners of the glass panel.
  • To attach the suction cups we sell, first position the suction cup with the movable handle parallel to the face of the glass panel (as highlighted in the first and second pictures).
  • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as highlighted by the third picture).
  • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Add Note Edit Step 2  ¶
  • Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
  • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
  • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
Image #1
Add Note Edit Step 3 — Display  ¶
  • Remove the eight T10 Torx screws securing the LCD to the outer case.
Add Note Edit Step 4  ¶
  • Carefully lay the iMac stand-side down on a flat surface.
  • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
  • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
  • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
  • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • Use a pair of tweezers to pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
Image #1
Add Note Edit Step 6  ¶
  • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
Image #1
Add Note Edit Step 7  ¶
  • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
  • Pull the display data cable connector away from its socket on the logic board.
Image #1
Add Note Edit Step 8  ¶
  • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
T10 Torx Security Bit Screwdriver
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
Popular Products
iPhone 4S Display Assembly
$94.95 · 50+ In stock
54 Bit Driver Kit
$24.95 · 50+ In stock
Detailing Brush
$2.95 · 23 In stock
iFixit Lock Pick Set
$29.95 · 27 In stock
