iMac G5 20" Model A1145 Optical Drive Replacement
Replace the optical drive in your iMac G5 20" Model A1145.
  • Add Note x
  • x 4
Use this guide to replace a broken optical drive.
Sections
Tools
first image
Add Note Edit Step 1 — Access Door  ¶
  • Orient the iMac face-side down on a table with the bottom edge facing yourself.
  • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
  • The screws are captive in the access door.
first image
Add Note Edit Step 2  ¶
  • Remove the access door.
first image
Add Note Edit Step 3 — Front Bezel  ¶
  • Remove the three T8 Torx screws securing the front bezel to the rear case along the lower edge of the iMac.
Next » « Previous
