Page 1 of 1
iMac G5 17" Model A1144 Hard Drive Replacement
- Author: Walter Galan
- Difficulty: Moderate
Upgrade your hard drive for an instant increase in storage space!
Sections
- Access Door 2 steps
- Front Bezel 7 steps
- Display 6 steps
- Hard Drive 4 steps
- Hard Drive Replacement 3 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 6
Re-orient your iMac so it sits upright on the stand.
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
Edit
Step 13
Peel back the aluminum EMI tape from the two vertical edges of the display.
During reassembly, it is helpful to use several small strips of tape to hold the EMI shielding along the left and right edges of the display footprint out of the way before lowering the display into the rear case of your iMac.
Edit
Step 17
Pressing the top of the hard drive bracket down to release it from the rear case requires a substantial amount of force, so we recommend laying your iMac stand-side down on a table to avoid knocking it over.
Press the hard drive bracket down toward the bottom edge of your iMac to free it from the rear case, then rotate the top of the drive toward yourself.
Lift the hard drive off its lower pins and pull it out of the rear case, minding the cables that are still attached.
When reinstalling the hard drive, be careful not to push the rubber grommets through the chassis with the hard drive pins as retrieving them may require logic board removal.
Edit
Step 22
Use the flat end of a spudger to pry the hard drive thermal sensor off the hard drive.
Don't forget to transfer this to your new drive.
If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Page 1 of 1
