first image
Add Note Edit Step 22 — Bottom Shield  ¶
  • Remove the following 10 screws from the bottom shield:
    • Six 3 mm Phillips
    • Three 7.5 mm Phillips
    • One 14 mm Phillips
first image
Add Note Edit Step 23  ¶
  • Lift the bottom shield off.
first image
Add Note Edit Step 24 — DC-In Board  ¶
  • Remove the single Phillips screw securing the DC-In board.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
iBook G4 12" 24x Combo Drive
$79.95 · 4 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
