first image
Add Note Edit Step 13  ¶
  • Remove the three hex screws using a T8 Torx screwdriver (or Allen screws using an Allen key if these are used).
  • The shorter screw is in the center of the computer.
first image
Add Note Edit Step 14  ¶
  • Remove the two Phillips screws on either side of the battery contacts.
first image
Add Note Edit Step 15  ¶
  • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
  • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 47 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
iBook G4 12" 24x Combo Drive
$79.95 · 4 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
