first image
Add Note Step 43
  • The bezel has several small, fragile tabs that will break easily.
  • Use a spudger to carefully depress the two tabs on top of the bezel.
first image
Add Note Step 44
  • Hold the optical drive on its side and depress the remaining tab to free the bezel from the drive.
first image
Add Note Step 45
  • Turn the drive over and remove the two Phillips screws from the bracket on the side of the drive.
  • These screws are only partially threaded.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Congratulations!
Share your repair story!
To reassemble your device, follow these instructions in reverse order. For more information, check out the iBook G4 14" 933 MHz-1.33 GHz device page.
Did you successfully follow this guide?
Notes
There are no notes
