Installing iBook G4 14" 933 MHz-1.33 GHz Fan (1.33 GHz)
Add Note Introduction
Guide specifically for 1.33 GHz models. Replacing a defective fan is pretty easy and will keep your laptop running cool.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
first image
Add Note Step 2
  • Lift the battery out of the computer.
first image
Add Note Step 3 — Lower Case
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
Notes
There are no notes
