first image
Add Note Edit Step 37  ¶
  • Turn the computer over and disconnect the orange hard drive cable, removing tape as necessary.
first image
Add Note Edit Step 38  ¶
  • Remove the two Phillips screws securing the hard drive to the metal framework.
first image
Add Note Edit Step 39  ¶
  • Lift the hard drive up, carefully guiding the cable through the slot in the lower case.
Next » « Previous
For more information, check out the iBook G4 12" 800 MHz-1.2 GHz device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
