first image
Add Note Step 31
  • Carefully lift the upper case about half of an inch and move it so that you can access the power and speaker cables.
  • If the upper case is sticking, it may be necessary to free the tabs holding the upper case to the metal framework along the outer edge of the battery compartment.
first image
Add Note Step 32
  • The connectors at the ends of the cables are attached very firmly to the sockets on the logic board. Pulling directly on the cable will either separate the cable from its connector or the socket from the logic board.
  • Lift the upper case enough to disconnect the blue and white power cable from the logic board. Using your fingernails or a dental pick, carefully pry the connector from its socket. Make sure you're pulling only on the connector and not on the socket.
first image
Add Note Step 33
  • Lift the upper case off completely and disconnect the multicolored speaker cable from the logic board. As before, make sure you're pulling only on the connector and not on the socket.
Add NoteNotes: Step 32
Flag Reply by chickenbrothel Mar 17 @ 5:32 PM
just pulled up the socket accidentally. #&^&
Flag Reply by textrix Mar 22 @ 6:42 AM
Quote from chickenbrothel:
It helps to use two small tools here: A dental pick (or similar) to hold down the socket (keeps it from separating from the logic board) and a small flathead screwdriver. With your off hand, use the pick to make sure the socket stays put; with your good hand, use the screwdriver. DON'T pry; instead, TWIST the head of the screwdriver to gently coax the connector out of the socket.
Flag Reply by jackshim Jul 10 @ 4:32 PM
Tweezers were also helpful here.
Flag Reply by hwn Jul 17 @ 11:39 AM
I left the power button cable as it is VERY easy to break. I instead left it plugged in, and flipped the upper case and metal shield up against the screen. Worked well.
Flag Reply by steweric Aug 18 @ 2:21 AM
I've just done the same thing DRAT ! Is there any way to solder the tiny socket back on to the board ?
Flag Reply by jyee Sep 1 @ 1:55 PM
First I released the plastic top. Then I removed the touch pad connector. With that, I was able to shift the top case down a inch so the power connector was exposed. I pressed a small screw driver along the middle on the long side of the power connector and twisted back and forth so it would wedge the connector from the socket. I left the speaker(long wires) wires connected and just flipped the case off to the left.
Flag Reply by QEII Student IT Nov 1 @ 1:30 PM
You don't have to remove the power button connector to remove most parts! It's really dodgy and can break your logic board. When you peel up the glue on the wire for the microphone connector, lean the upper case on the display.
