first image
Add Note Edit Step 40 — Hard Drive Replacement  ¶
  • Remove the hard drive bracket from the left side of the hard drive.
first image
Add Note Edit Step 41  ¶
  • Remove the two black T8 Torx screws from either side of the hard drive (four screws total).
first image
Add Note Edit Step 42  ¶
  • Use the transparent orange loop to disconnect the large orange ribbon cable from the hard drive.
  • This is a bit tricky. Try rocking the cable gently from side to side while applying even pressure. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
  • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
Next » « Previous
For more information, check out the iBook G4 12" 800 MHz-1.2 GHz device page.
Did you successfully follow this guide?
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 14 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
Notes Add Note Notes are offturn on
