Steps 1–2: Battery
Steps 3–9: Keyboard
Steps 10–21: Lower Case
Steps 22–23: Bottom Shield
Steps 24–26: DC-In Board
Steps 27–33: Upper Case
Steps 34–35: Top Shield
Steps 36–38: Modem
Steps 39–44: Display Assembly
Steps 45–48: Rear Display Bezel
Steps 49–55: LCD Cover
Steps 56–57: Clutch Cover
Steps 58–60: Display Data Cable
Parts
iBook G4 12" 800/1/1.2 GHz Display Data Cable
$14.95 · 9 in stock
Tools
Spudger
$2.95 · 289 in stock
Flathead 3/32" Screwdriver
$4.95 · 21 in stock
Phillips #00 Screwdriver
$4.95 · 52 in stock
T8 Torx Screwdriver
$4.95 · 98 in stock
I had a hard time getting the Airport card seated properly when reconstructing. If the wire brace doesn't snap back in easily, then try reseating the card. Don't force it.
THANK YOU SO MUCH FOR THIS TUTORIAL!
Honestly, this is a lot easier than it looks. The key is take your time and don't force anything. Use tweezers to disconnect cables from logic board. Also, use a mini-head screwdriver like for glasses to pry the case open and go slowly.
