Once the front and sides of the lower case are free, turn the computer so that the back is facing you and pull the lower case up and toward you until the back tabs pop free (it may be helpful to jiggle the case up and down).
Step 14
Remove the small greasy springs with white plastic caps from either side of the battery contacts.
Step 15
Bottom Shield
Remove the 4 Phillips screws from the bottom shield.
The two longer screws are along the computer's edge, near the ports.
Notes
There are no notes
