Installing iBook G3 Clamshell Hard Drive
Add NoteIntroduction
How to remove the hard drive, along with its cable and bracket from your computer.
Parts relevant to this guide
first image
Add NoteStep 1 — Battery
  • Use a coin or large flathead screwdriver to turn both battery locking screws 90 degrees to the left.
  • Remove the battery cover.
  • Remove the battery from the computer by pulling up on the plastic tab.
first image
Add NoteStep 2 — Airport Card
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
first image
Add NoteStep 3
  • If your computer does not have an airport card, you can skip the next two steps.
  • Grasp the clear plastic tab on the airport card and pull up and toward the display.
Notes
There are no notes
