Page 1 of 1
iBook G3 Clamshell Hard Drive Replacement
- Author: iRobot
- Difficulty: Difficult
You can install hard drives up to 9mm thick.
Sections
- Battery 1 step
- Airport Card 3 steps
- Keyboard 3 steps
- Upper Case 9 steps
- Optical Drive 3 steps
- Modem 4 steps
- Display 5 steps
- EMI Shield 5 steps
- Hard Drive 2 steps
- Hard Drive Replacement 1 step
Files
- View:
- Paginated
- Full width
Edit
Step 2
Airport Card
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
Edit
Step 14
Do not lift the upper case too far without first disconnecting the audio cable.
Push out the rim of the lower case and pull up on the upper case, grasping it just to the left of the optical drive.
Repeat the above step on the upper left corner of the upper case, grasping the bottom left corner of the upper case.
Edit
Step 16
Grasp the upper case on either side of the keyboard space and rotate up and away from the screen.
You may be thinking you're about to break your upper case. Not to worry - the tabs holding the upper and lower cases together are very strong. Simply apply even pressure and continue to rotate the upper case up and away from the screen until it comes free.
Edit
Step 19
Lift up on the optical drive while sequentially pushing the small plastic tabs one after another toward the screen to free one side of the drive.
Lift up the side of the optical drive you just freed and slide the drive out and away from the screen.
When reinstalling the optical drive, be sure that the drive tray is out far enough to slide under the lower casing rim.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
Edit
Step 20
Modem
Remove the following Phillips screws:
Remove the longer Phillips screw from the middle-rear of the modem shield.
Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
Remove the larger Phillips screw that secures the EMI fingers to the modem board.
Remove the EMI fingers.
Edit
Step 32
There are six screws to remove (if you have an iBook without Firewire the screw circled in orange will not be present):
Two short, flat-headed Phillips screws near the battery compartment.
One short, round-headed Phillips near the speaker cable connector. (This is present on some models, but not others - especially the older ones)
One short, flat-headed Phillips between the ethernet and USB ports.
One short, flat-headed Phillips to the left of the hole-y (polite laughter) area.
One long, round-headed Phillips screw near the power receptacle.
Edit
Step 36
Take the metal bracket away from the hard drive.
Disconnect the hard drive cable from the hard drive by applying even pressure on both sides while maintaining a firm grip on the drive itself.
This is a bit tricky. Try holding the drive against your body while pushing the cable away from you, or rocking the cable gently from side to side while applying even pressure, or both. If you bend the pins, do your best to straighten them, using the hard drive cable as a guide.
Page 1 of 1
