first image
Add Note Edit Step 10  ¶
  • Pull the CD-ROM drive tray partly out.
  • Remove the silver Phillips screw from the plastic casing.
first image
Add Note Edit Step 11  ¶
  • Turn the computer over.
  • Remove the three Phillips screws.
first image
Add Note Edit Step 12  ¶
  • This is a diagram of the trackpad ribbon clamp connector you will disconnect in the next step.
  • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
  • 2) After disengaging the locking bar, slide the cable out of the connector.
Next » « Previous
Required Tools
Phillips #0 Screwdriver
$4.95 · 50+ in stock
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Popular Device Products
Notes Add Note Notes are offturn on
