first image
Add Note Edit Step 55  ¶
  • Disconnect the DC cable from the logic board.
first image
Add Note Edit Step 56  ¶
  • Remove the three Phillips securing the heat sink to the metal framework.
  • Remove the rear plastic grill.
first image
Add Note Edit Step 57  ¶
  • Lift the heat sink out of the computer.
  • If you need to mount the heat sink back into the laptop, we have a thermal paste guide that makes replacing the thermal compound easy.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
