first image
Add Note Step 52 — Logic Board
  • Remove the following 9 screws:
    • Two 3 mm Phillips from the edge of the logic board, near the battery
    • Two 4 mm large head Phillips on the port side, from either corner.
    • One 6 mm Phillips near the sleep light.
    • Two 7.5 mm Phillips securing the battery connector to the metal framework.
    • Two 5 mm Phillips from the logic board. These screws may not be present on some models.
  • There will be two screws remaining that secure the airport card cage to the logic board (can't get them all).
first image
Add Note Step 53
  • Disconnect the sleep light from the logic board.
first image
Add Note Step 54
  • Disconnect the DC cable from the logic board.
Notes
There are no notes
