first image
Add Note Edit Step 43 — IO Bezel  ¶
  • Remove the single Phillips from the white plastic finger of the IO Bezel.
first image
Add Note Edit Step 44  ¶
  • Slide the IO Bezel away from the computer and off.
first image
Add Note Edit Step 45 — Display  ¶
  • If you have already removed the hard drive, ignore its presence in the following steps. The hard drive does not affect the display removal.
  • Disconnect the microphone cable from the front, left corner of the logic board.
  • Peel back the black tape and free the microphone cable from the hard drive.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
