first image
Add Note Edit Step 37  ¶
  • Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
  • Disconnect the modem cable from the upper, left corner of the modem.
first image
Add Note Edit Step 38  ¶
  • Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
first image
Add Note Edit Step 39 — Hard Drive  ¶
  • Remove the single Phillips screw to the right of the hard drive connector.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
