View profile
Logout
« Previous
Next »
Page 10 of 20
Lift the upper case off completely and disconnect the red and black speaker cable from the logic board.
Make sure you are pulling only on the connector and not on the socket.
Peel back the yellow tape and foil shielding.
Remove the following 10 screws:
One 5 mm Phillips at the upper, right corner of the battery compartment.
Nine 6 mm Phillips scattered around the shield.
Lift the bottom shield off.
Next » « Previous
$6.95 · 48 in stock
$7.95 · 13 in stock
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$299.95
$24.95 · 50+ in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$6.95 · 50+ in stock
1024
