Installing iBook G3 14" Display
Add Note Introduction
Change out the entire display assembly, including the inverter, Airport antenna, hinges and plastic casing.
Parts relevant to this guide
Paginated Single Page Steps
first image
Add Note Step 1 — Battery
  • Use a coin to rotate the battery locking screw 90 degrees clockwise.
  • Lift the battery out of the computer.
first image
Add Note Step 2 — Keyboard
  • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
  • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
  • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
first image
Add Note Step 3
  • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
  • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
Notes
There are no notes
