first image
Add Note Edit Step 4  ¶
  • Grasp the clear plastic tab on the Airport card and pull toward the right.
first image
Add Note Edit Step 5  ¶
  • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
first image
Add Note Edit Step 6  ¶
  • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
iBook G3 12" Top Shield
$14.95 · 13 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
