first image
Add Note Edit Step 25  ¶
  • Use a straightened paperclip to open the optical drive tray.
first image
Add Note Edit Step 26  ¶
  • Pull the optical drive out just enough so that you can access and remove a Phillips screw near the battery compartment.
first image
Add Note Edit Step 27  ¶
  • Pull the optical drive a bit more so that you can access and remove a second Phillips screw near the power receptacle.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
