first image
Add Note Edit Step 43  ¶
  • Move the display data cable to the right in order to access and remove a single Phillips screw.
  • Remove the single Phillips screw remaining at the upper, right corner of the modem.
first image
Add Note Edit Step 44  ¶
  • Lift the modem from the logic board on the right side, being careful not to strain the display data cable.
  • Disconnect the modem cable from the left side of the modem.
  • Slide the modem out of the computer, being careful to avoid catching the black plastic shielding on the surrounding cables.
first image
Add Note Edit Step 45  ¶
  • Your laptop should look approximately like this.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 48 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
