first image
Add Note Edit Step 10  ¶
  • Use a pin (or anything you like) to remove the three rubber feet from the lower case.
first image
Add Note Edit Step 11  ¶
  • Remove the three 5.2 mm newly-revealed Phillips screws.
first image
Add Note Edit Step 12  ¶
  • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50 in stock
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Flathead 3/32" or 2.5 mm Screwdriver
Coin
$2.95 · 16 in stock
Related Products
iBook G3 12" DC-In Board
$24.95 · 4 in stock
Recommended Tools
Home Tech Toolkit
$24.95 · 50+ in stock
Sorting Tray
$7.95 · 50+ in stock
Anti-Static Wrist Strap
$7.95 · 13 in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$6.95 · 50+ in stock
Notes Add Note Notes are offturn on
